hair poking through forehead fix?
this image shows vintage curl hair on g8f poking through but it has happened with other hair on genesis also
842 x 932 - 1M
  • VicSVicS Posts: 1,273
     if it not in iray preview the poke through hair doesnt show either so cant try to use mesh grabber on it
  • barbultbarbult Posts: 27,618
    There must be about a thousand threads on the same subject already. Change your Render Settings Inatancing Optimization to some setting other than what it is on now. Change it to Memory or Speed.
    edited October 2022
    thanks barbult!
    Post edited by VicS on
    edited November 2022
    still using  vintage curl hair  trying all 3 settings under optimization the marks on her forehead don't get hidden anymore, it did work but this file has been reopend and the marks have appeared again i tried replacing with new  vintage curl hair  also
    546 x 475 - 505K
  • StratDragonStratDragon Posts: 3,290
    most hair comes with morphs for specific model figures and most of them can be adjusted with one or more of those tabs to clean the poke through. also the x,y,z scale bumps in small increments will also do it.
    I forgot to even check hair sliders, thanks for the tip StratDragon
