In The Market For A New PC
Hello!
I don't post here very often; I think this is my second time here, so forgive me if I'm in the wrong place.
I am in the market for a new PC since my old one is nearly a decade old and was not built with DAZ in mind. I was hoping some people here could help me since I'm not very knowledgeable about computers.
I'll set the price range to about $3,500.00 for the PC.
The PC needs to be built with DAZ3D in mind as its primary function, but can also be used for gaming.
Thanks!
  • I'm surprised no one answered the call. People are usually bursting at the seams with information.
    Were you planning on making an attempt to acquire the parts and then assemble yourself or have someone do it for you?
    This forum thread about iray rendering hardware benchmarking could be insightful since it provides some PC specs throughout - https://www.daz3d.com/forums/discussion/341041/daz-studio-iray-rendering-hardware-benchmarking#latest
    Could give you a good general idea of what other people are using.
    A recent Nvidia RTX GPU with minimum 8GB's of VRAM (preferably more) and minimum 32GB's of RAM is all it takes to run DAZ Studio, but when one gets hooked, one is going to need a 4TB external USB drive for the content.
  • 12gb min RTX GPU and 64gb RAM. 1000w PSU for future GPU upgrades
  • ExpozuresExpozures Posts: 268
    Daz-wise, CPU doesn't make a huge difference.
    You want as much VRAM on your video card as you can afford.  From the looks of it, the 4090-series right now doesn't have much of a performance increase in Daz, but that doesn't mean that it will always be this way.  It's possible that a newer version of Daz will utilize the new CUDA drivers and wind up using the full potential of the card.  But...there's no info on when that's coming down the pike.
    That said, you're also going to want to consider future upgradability.
    Case : Corsair 4000X
    Exterior Color : Black
    Processors : AMD Ryzen 7 5800X3D 8-Core 3.4GHz (4.5GHz Max Boost)
    Motherboard : MSI B550-A Pro
    Memory : 64GB CORSAIR VENGEANCE RGB RT DDR4 3200MHz (2x32GB)
    System Cooling : Corsair H60i PRO XT
    System Fans : ORIGIN PC Standard Fan Kit
    Graphics Cards : NVIDIA 24GB GeForce RTX 4090
    Operating System : MS Windows 11 Home
    Operating System Drive : 500GB Samsung 970 EVO Plus PCIe NVMe M.2
    RAID : No RAID
    Hard Drive : 2TB OPC Approved Powered by Samsung
    Power Supply : Corsair RM1000x Series PLUS GOLD
    Power Supply Sleeved Cable : No Sleeved Cable
    Audio : Integrated High-Definition Audio
    Networking : Onboard Network Port
    The ORIGIN Difference : The Best Gaming Experience Guaranteed - Neuron 4000
    24/7 U.S Based Warranty : 1 Year Part Replacement with 45 Day Free Shipping
    Current Special Offer : Free US Ground Shipping
    Current Special Offer : October Promo: Get $200 Off All Desktops
    Free ORIGIN PC Gear : ORIGIN PC T-Shirt
    Free ORIGIN PC Gear : ORIGIN PC Mousepad
    There could probably be some tweaking to suit your needs.  But, I'd definitely go min Ryzen 7 or i7 CPU.
  • nicsttnicstt Posts: 11,715
    agreed - as a minimum on the gpu.
     That's my hang-up right now...I've got an RTX 3070, which isn't bad but starving for VRAM.
  • kyoto kidkyoto kid Posts: 42,403
    ...a few caveats about the specs above.  First, there may be a delay before the 4090 will be useable with Daz like we've seen with past  releases of Nvidia GPUs.  Second, I would recommend 128 GB for system memory particularly if you plan to get them most out of that 24 GB of RAM. Textures are the biggest issue and 4k is pretty much the norm with 8K showing up now and then  Textures by far take the most VRAM/memory compared to geometry.  If the Daz drive is a conventional HDD (type not specified above) I'd consider at least 4 TB.
  • jmtbankjmtbank Posts: 189
    With a huge $3500 budget, I would probably build a 4090 , AMD 7600,  B650 motherboard, 64GB ddr 5 system.
