adjust rigging to shape on 3rd party model?
Hi Yall,
Does the adjust rigging to shape feature only work on morphs shape changes?
e.g. I bring in a fuse model, I use the transfer tool to get a genesis rig into it, no problem.... but I can't then use "adjust rigging to shape" to make it fit properly.
Is this not working because the mesh has to be a morphed genesis mesh?
Thanks
Jamie
  • Richard HaseltineRichard Haseltine Posts: 111,430
    The figure needs to be morphed - the function tries to move the joint centres (and optionally reorient the bones) so that their relation to the morphed mesh is the same as their relation to the base mesh. So for it to do anything the joints have to be correctly set in the base mesh, and memorised, then a morph has to be applied to the figure.
  • ok, thank you for your response.
