Iray Glossy
reelyorreelyor Posts: 237
I've tried a search and haven't had much luck.
How does one increase the "shine" on Victoria 7 skin to simulate a wet skin? I have increased the glossy reflectivity but it doesn't seem to do anything.
I am not looking for water droplets or anything like that, just shinier skin.
Thanks
  • Richard HaseltineRichard Haseltine Posts: 111,332
    Try using the top coat settings.
  • reelyorreelyor Posts: 237
    Thank you Richard.
  • AlienRendersAlienRenders Posts: 806
    In iRay, it's not called glossiness anymore. It's called roughness. They're the same thing, but inverted. Lowering the roughness will make it shinier. And to make things even more confusing, glossy in iRay is more like specular where it adjusts the intensity. To get shinier skin, you could start by lowering the glossy roughness by .1 and also lower the top coat roughness by .1. You can adjust from there.
    Thank you, AAlienRenders!!!
  • Oso3DOso3D Posts: 15,115
    What's weird is that you have three general modes:
    PBR Metallicity/Roughness
    PBR Specular/Glossiness
    PBR Weighted
    The first has a roughness measure, with things generally going from 0 (very high shine/tight highlights) to 1 (very low shine/spread-out highlights).
    The second has a glossiness measure, with glossiness from 0 (very low shine/spread-out highlights) to 1 (very high shine/tight highlights).
    So... yeah, that's weird.
    There are a bunch of other subtle differences. Generally, you want Metallic for metals (duh) and other glinty types of things (rocks, plastic, etc?) Specular is better for soft skin, organics, wood.
    At least that's what I've been told. I haven't noticed one heck of a difference between, say, .5 Roughness Metallic, and .5 Glossiness Specular, except Metallic has a 'metallicity' slider which is handy for reflective surfaces.
