Merging human to Spider help
enchantee790
Hi all, hope you are well.
I bough the spider package and is trying to put the human form to it. I am not sure how to fuse the spider body and the human together.
The spider body just walks off by itself...
Is there a way to keep the rig and add the human body no legs to make the spider please?
I started using Daz about 2 weeks now. Thanks in advance :)
Kim
564 x 532 - 799K
Post edited by enchantee790 on
You would need to parent the human to the spider body-part that it shouldmove with - what that is will depend on how the spider is rigged, if it is anatomially correct it would probably be the Head. You can do that by right-click in the Viewport>Change "Huamn" Parent or by drag-and-drop in the Scene pane - either way you want Parent in Place on (it's a check-box at the bottom of the parent dialogue or a checkable menu item in the Scene pane option menu)
Thank you very much and sorry about the horribly late response
