Hope I'm in the correct forum for this...
I hope I'm in the right forum...bit difficult to tell...
I have been using Daz Studio General release and also the Beta side by side...two versions. It's not a problem...they are the latest updates as of 15 October 22...
Although I have no problems with either, I'd like to ask something. I have long produced images with the Beta mostly...so, after some time now, I have accrued a lot of personal scripts in the script menu therein...Is there a simple process to populate the scripts menu in the General release with the same numerous scripts that I have in the Beta...?
Copy and paste..? Something idiotically simple like that..?  I have been reticent to try anything because I don't want to harm the respective installations of the two versions...
Thanks for any ideas on this...
  • marblemarble Posts: 7,500
    Good Question. I'm on an old beta because I am putting off having to recreate my custom actions, etc.
  • 3WC3WC Posts: 1,165
    edited October 2022
    There is a script for that. Let me see if I can find it...
    It's called "Copy UI from Channel", I will see if I can find out where I got it from. It basically copies your whole layout from one version of DS to another, so, for example, from the beta to the regular release.
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/general_ui/copy_ui_from_channel/start
    Found it!
    Post edited by 3WC on
  • Thank you to both responses above...And special thanks for the script.  Although, I will now have to figure out how exactly to use it. I'm just not a programmer. But I will try. Thank you. I now know that it is possible at least.
  • I'm assuming I run it with the script IDE tab in the interface. But I am unsure of things after that. Would it run first in the Beta to more or less "copy" the preferred beta interface setup and then run the same script again in the general release of Daz Studio to apply that beta interface..?
    Sorry to be a pest. But thanks for any help.
    Found it!
    You are an absolute genius...that worked flawlessly from the ScriptIDE window inside the general release. All instantaneously accomplished. Something I have spent a very long time TRYING to do. Thank you. The best thing I've done in some time is to post my question here...
    Thankyou, 3WC...
    "Click the name of the example below to save it as a file"
    There is also this. You can save the file anywhere in your content library, then add it to your script menu, or whatever you want.
    I will do that, too...
    Again, I cannot thank you enough, 3WC...you would not believe how long I have been trying to do this.
    Thank you.
    You're welcome. I help when I can. :)
