Help me find some settings in Studio
I had to reinstall my computer and thus daz studio and now the sliders on the parameters tab have become ginormous, with at least a 10 pixel gap between them, so barely a few sliders fit on screen at any given time.
Before reinstall my sliders were much smaller with virtually no gap in-between, how do I make it so again?
Post edited by mumia76 on
Window>Style>Select Style.
Thanks, changing the style did make the sliders smaller, unfortunately it also makes the text on other panels very small. Is there a way to get the small sliders but keep the slightly bigger fonts? I could only find how to change the colors of things.
I edited the topic title, because there are other things that are not as they used to be and I can't find the solution:
You mean the dialogue when saving or when holding down cmd/ctrl on loading?
Save as has always asked for a name,. the options dialogue is new.
Yes, it used to remember the last used options, now it always reverts to defaults.
Of course it asks for a file name, that's why it is save as. But the additional dialogue was not there, and it is not very helpful as these settings can be pre-set from preferences. They don't seem something that you'd want to change every time you save a new scene.
So is there no solution to this? It's really annoying. I'm used to just CTRL-clicking to load partial poses, now I can't do that because the dialogue always reverts to affect root instead of selected.
Shift-double-click will apply your preferred settings, which you can set in the dialogue before closing it.
Shift double click on What? If I shift double click on a pose, it just loads the full pose as if I simply double clicked on it.
You need to set your rpeferred options first - ctrl-double-click and in the dialogue that lets you set options there is a second tab covering setting the preferred state.
There must be a 4.21 UI glitch, I'm using the Highway GUI style and there is no visible second tab on this dialogue for me. But when I click where it is supposed to be it is actually there, just invisible. That's why I couldn't find it.
The tab shows up correctly in the symmetry context menu however, it is not invisible there.
Which style are you using? One of them does make it well-nigh impossible to see the labels of inactive tabs.
As mentioned highway, but this was not an issue in 4.20.
Maybe it had been tweaked and has now reverted, I don't have and older version installed to check but it certainly has been an issue in the past.
