Problem with Iray shaders
Hello, I have a little problem. As I try to select a surface to apply a shader that come by default in daz 4.8, shader Overrides the material, even though he said he did not do it, because I applied it with the control key. Anyone know why that happens?
  • SimonJMSimonJM Posts: 6,102
    Are you sure, when you ctrl-clicked, you had Ignore rather than Replace selected in the options dialog?
    15K
  • IsazformsIsazforms Posts: 210
    Look at this!!! The material changes.
    1360 x 726 - 520K
    1360 x 729 - 341K
    1360 x 730 - 812K
    Yes...but does it render correctly?
    edited July 2015
    No , it goes with the other material. It looks very blurry.
    Remember ever moved an adjustment so that the material did not look big and fuzzy,
    but smaller, but can not remember .
    I understand that the material is replicated on the surface with a certain size as a mosaic.
    I remember seeing somewhere that could change that size.
    Post edited by Isazforms on
    You need to adjust the tiling for the diffuse map.  In your third screenshot, above, it looks like the tiling options are covered by the image of the asphalt.  I think they are the two 4.00 items...probably start at 12.00 for both horizontal and vertical tiling.
    Oh, Thanks again!
  • Richard HaseltineRichard Haseltine Posts: 111,758
    edited July 2015
    I see this going from the Default DAZ Shader to Iray Uber Shader using the Asphalt preset, but not if I change the diffuse map with the Iray Uber Shader applied. It's probably worth making a bug report (by opening a suppot ticket http://www.daz3d.com/help/help-contact-us ).
