220 Expressions Genesis not working
I installed 220 Expressions for Genesis today because characters without facial expression are not all that much use to me but it didnt work the expressions did not exist anywhere in the program's database and I couldnt drag them onto the character to use them either.
if anyone can instruct me on how to fix this will be apreciated.
  • LeanaLeana Posts: 13,670
    Those are morphs only, you won't see anything in your content directory, but you should have new morph sliders in the Parameters tab.
  • LXBlackLXBlack Posts: 25
    Well i looked where my morph sliders usualy are. That was the first place I looked but I might not have checked the parameters tab. That might be where my other missing morphs are hiding too.
    And some only show on the correct part.  You may need to select the head to have some of them show...
    Ok I understand that some people dont try these things but I I have. I went to parameters and checked under the head because I wouldnt expect expressions to be on her buttocks but they are not there either.
  • fixmypcmikefixmypcmike Posts: 19,742
    Did you have the Head selected, or the entire Genesis?
  • barbultbarbult Posts: 27,655
    Here is a screenshot of how to select the Genesis head and dial the expression.
    2000 x 1154 - 626K
    If you have done all of the above, and still can't find these expressions, then they have not been installed into the correct place.
    How did you install these files, using DIM (DAZ Install Manager) or unzipping the file yourself?   If you used DIM, then they will be installed by default into : C:\Users\Public\Documents\My DAZ 3D Library and Genesis needs to be installed there as well.
    Ugh. Found them. Thank you to Barbult for that picture I'd never have found them without that.
