Iggy Hair
I'm working with Iggy Hair for Genesis. Before any modifications the hair looks normal. When I change Genesis to a basic child, I can no longer see the bow. Any ideas?
495 x 640 - 232K
  • DarkSpartanDarkSpartan Posts: 1,096
    Are you applying the hair before or after you dial the morph? Whichever it is, do it the other way and see if that helps. Sometimes scaling isn't perfect, and that can compress the mesh in strange ways.
  • I've tried fitting before and after applying the morphs. I've also tried parenting to the character both before and after the morphs. I think it must be an issue with the compression. Guess I'll have to make a women look like a child without shrinking her.
    edited July 2015
    I've been having fits with Genesis and various hairs.  The same ones giving fits on Genesis work fine on G2 and G3...
    It's especially bad with some of my sculpted morphs.  They just don't want to be incorporated to the hair and I'm not going to  try to manually do it.
    You may want to check the scaling on the bow, if it is separate geometry.  It could be getting scaled down, twice.  If you select the bow and go to Parameters and Show Hidden, then Currently Used...if the child shows up, back it off/zero it out.
    If it's part of the hair and not separate, so that it's just a material zone instead of being a 'part', you'll have to hide it (zero out the opacity/cut out in Iray) and then load another copy of the hair, this time hiding everything except the bow.  Then position it before parenting.
    Post edited by mjc1016 on
  • PITA no matter what. Do you know if there a morph for changing GN2F into a child like Genesis does?
    Yes, there's a couple
    One is Zev0's Growing Up packs.
    http://www.daz3d.com/growing-up-bundle
    There's a freebie set at ShareCG
    http://www.sharecg.com/v/76705/gallery/21/DAZ-Studio/Genesis-2-Children
    And there was one given away at Christmas, last year or the year before...
    I got growing up for GN2F and still have the same problem with the Iggy Hair
