Help with creating JCMs for Genesis 2 and 3
Currently trying to create a simple JCM for clothing for the above. I found this tutorial which appears to be outdated http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/assembling/tutorials/creating_joint_controlled_morphs/start
It's apparently updated by this forum posting http://www.daz3d.com/forums/discussion/41396/
The problem I'm having is that I cant seem to find the new property hierarchy pane mentioned in the forum posting. I'm using Daz 4.8 advanced.
Is there a simple way to link up a JCM that I'm missing ?
  • Richard HaseltineRichard Haseltine Posts: 111,792
    Window>Panes(Tabs)>Property Hierarchy
  • MihrelleMihrelle Posts: 95
    Sorry but I really cant see it in Daz 4.8 advanced under Windows Panes (tabs) - honestly it's really not there ! Could it be called something else ?
  • 3WC3WC Posts: 1,168
    It is there, unless your DS installation is corrupted somehow.  Don't know if it has anything to do with what Layout you are using?
    Did you enter your serial number? if the title bar stil says DAZ Studio Standard then you didn't, and the advanced tools will not be enabled.
    That seems to have sorted it - The title bar was saying advanced but for some reason when I checked the 'about installed plugins' that particular pane wasn't activated. I re entered the serial number again and that did it, Thank you :)
    The rigging tools require the Pro version, so no Advanced wouldn't have been enough.
