Is There an Automated Product for Bringing V4 & Genesis UV Textures to G2?
Greybro
I'm think that there must be.
Yes, there are the V4 UVs for Genesis 2
http://www.daz3d.com/victoria-4-for-genesis-2-female (that would pretty much be the manual way)
Then if you have that you can use this...
http://www.daz3d.com/v4-skins-auto-converter-for-genesis-2-female-s
or
http://www.daz3d.com/v4-skins-batch-converter-to-genesis-2-female-s
Thanks for the quick answer. I guess there's no way to move a V4 morph over to G2 though right. Turns out I already owned the auto texture converter.
GenX2 for morphs
Or a 'by hand' method exists...
http://www.daz3d.com/forums/discussion/24093/transferring-morphs-from-genesis-to-g2m-g2f-and-from-g2m-g2f-to-genesis-now-with-clones-works-on/p1
If this works as advertised, well that would just be awesome!
Thanks for the info folks. Much appreciated.
I hope you don't mind me piggy-backing on this thread, but this is falling in to my issue as well:
I need a way to convert an existing V5 UV skin builder material to a V6 UV skin builder material. I've run into an issue where using the V5 UV doesn't return the right result when rendered, and if I just tell the material to use the V6 UV, everything shifts and splits at various seams around the figure.
I honestly don't want to go back through the pain of rebuilding the skin, so if I can find a way to convert the UV from V5 to V6 (relatively) painlessly, I'd like to do it.
I checked through the threads listed in the previous replies here, but I don't see a solution presenting itself. :(
Any help is greatly appreciated. Thank you!
