Convert NLA to Keys?
DondecDondec Posts: 243
edited July 2015 in Carrara Discussion
Maybe I missed it somewhere, but Is there any way to convert NLA animation clips to Carrara keys?
I posed a Genesis figure, then later decided to use a G2F instead.  I figured out how to mostly transfer the pose using NLA (darnit, I wish the Memorize and Restore Pose feature worked across figure generations).  Anyway my pose got converted with NLA, but every time I want to tweak some little thing, I have to enable/disable editing on the Clip.
Thanks in advance
   - Don
Post edited by Dondec on
  • 3DAGE3DAGE Posts: 3,315
    edited July 2015
    In the NLA Panel,. You should see an option to ( Load Clip Data )
    This opens a little panel where you can select any Clip currently loaded in the Scene / Clips area.
    Once you select a clip, Carrara will Load the NLA Clip Data into the Sequencer timeline as Key-frames which can then be edited, added to, and saved as a New NLA Clip.
    Hope it helps
    Post edited by 3DAGE on
  • DondecDondec Posts: 243
    Thanks 3DAGE ... in plain sight too.  Have to laugh.
    Thx again
        - Don
