Moving Morphs from Centuar 8 to Centuar7
carrie58carrie58 Posts: 4,171
edited October 2022 in The Commons
ChangelingChick made the wonderful morph set "Centuar Breeds" for Genesis8 Centaurs,  https://www.daz3d.com/cc-centaur-breeds-for-genesis-8-male-and-female-centaur I want to know if there is some way to move them to Genesis7 Centuars ,and if there is how can I do it ? I notice that the morphs are coming up in Genesis 8 figure morphs ,does that mean I could use one of the character converters ?or would it not work because it's a geographed figure .......any help will be appreciated
Post edited by carrie58 on
  • GordigGordig Posts: 10,797
    Seems like you could apply the morphs to the figure, then export just the geograft and import them as morphs on the G7 geograft, since as far as I know they're identical. I believe it's possible to spawn the morph controller on  G3, or move it after creation. I've done similar things in the past. I'll play around with it tomorrow.
    I just tried it, and it turns out that the G3 centaur basically has an entire G3 torso built into it, so they're not the same mesh.
  • carrie58carrie58 Posts: 4,171
    edited October 2022
    Thank you @Gordig , couldn't be something easy ....... I really wish CC had made the breeds for G7Centaur  ......
    edited October 2022
    Hmmmm been struggling with this most of the day Gen3 Centaur does have the "male centaur additive " and that is just the centaur horse body , and if I unparent the Genesis8 male Centaur body from the Genesis8 male ,then delete the Genesis8 male,eyelashes and Geoshell ,drop the resolution on both bodies to base ,........ then I have 2 centaur bodies that look the same ,so does that mean I could then ,apply a shape to the G8horse body ,export it ,then import that shape as morph on the G3 horse body ?
    If you switch to the geometry editor, you can see that, actually, both G3 and G8 centaur bodies have the entire human torso mesh...which, unfortunately, also means that G3 centaur body has eyelashes, while G8 centaur body doesn't.
    hmm geometry editor ....going to go look ,and probably cuss in private .....I so wish I had been younger when learning this stuff ........
  • According to Greek mythology, Chiron was a half human/half horse doctor which made him the Centaur for Disease Control.
    Haahaahahah very good !!
