genesis 3 and ds4.6?
wgwalton01wgwalton01 Posts: 27
hi
does genesis 3 work with ds4.6.
thanks in advance
bill
Post edited by wgwalton01 on
  • Yes, it works fine with DS 4.6.
  • wgwalton01wgwalton01 Posts: 27
    thank you, good to know.
    bill
  • XaatXuunXaatXuun Posts: 882
    oh that is good to know, I second the Thank you
  • BejaymacBejaymac Posts: 2,014
    It will load, just don't expect half of it to work right as most of the tech needed isn't in 4.6.
    been playing with G3F , so far seems to fine for me, just less dials to play with. very limited in dialing in shapes , actually zip .  I found some freebie face morphs ..
    poses other then ones for G3F don't work, well they half work . . some hairs don't follow well when  changing poses,  just have to find the right part to parent to, then it stays.
    I'm not sure if that is a 4.6 reason, or just that I'm using products from V3 - Genesis 2
    here is  what I have rendered so far (not counting a couple I goofed on or forgot to adjust something before the render)
