Touch genesis 8 clothing and the texture disappears.
Hello everyone,
When I put clothes on my genesis8.
If for example I articulate my arm and it presses on the clothes, the texture of the clothes disappears.
Is there any way to disable this?
I don't want the texture to disappear when touched.
Thank you.
  • IceCrMnIceCrMn Posts: 2,334
    The texture isn't disappearing.
    What is happening is the smoothing modifier on the clothes is being pushed inside the character because the hand is passing through both the clothes and the characters body.
    To fix.
    Adjust the pose so there is a small amount of space between the hand and clothes.Adjust in very small amounts until you see the problem go away.
    Very common for this to happen.
    You will get better with these types of adjustments over time with more experience.
  • xavixavi Posts: 12
    To fix.
    Hello, I already know that solution.
    But if I want to make an animation and the hand touches the clothes this happens. And I have to fix it with photoshop.
    One frame nothing happens but if there are many it's a tedious job.
    There must be a solution so that this doesn't happen.
    Cheers.
    I really don't see any other way to fix this.
    There is a mesh intersection.
    The hand mesh is passing through both the cloth and the body mesh and the cloth is getting trapped between them and pushed inside the body mesh.
    Adjusting the pose on the frames this is occurring is the only way to fix it.
    You maybe able to adjust the pose on frames before the problem starts so you avoid to begin with.
    I do this routinely when I do dforce animation for cloth sims.
    Sorry I can't be more help.Good luck.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,685
    turn off the smoothing and hide the body parts that are under the clothes and or expand the clothes if they have a slider for it
    It worked!
    thank you very much. And thank you very much to both of you for replying.
