Genesis 3 joint limits
Another day another Gen3 question. I often turn off joint limits to push poses, particularly in the face on brows mouth etc. I notice on Genesis 3 if I turn off limits on MouthOpen and Mouth Open wide after a certain value the jaw reverses direction in an odd popping way and starts to close again?
Anyone else experinece this?
  • MattymanxMattymanx Posts: 7,002
    I have noticed something simular with the limbs on G3F that if you just push the limits for fun you will notice a bubble effect then it kinda returns to normal.  If you keep doing it it just keeps doing the same thing.  Not a major issue personally.
    G3F has bones that control the facial features and the morph diasl are actually control dials that adjust the bones and may set some hidden adjustment morphs.  If you push the dial to far you could rotate the jaw more than 360 degrees.  For finer control of the facial features you could check the Show Hidden Nodes in the options for the Scene pane and manipulate the bones directly.
