Shaders not working when i click.Please help me
Hi i am Haluk.When i click to shaders nothing happen.No error,no load.Can you help me ?
  • Did you select the surface you wish to affect?
  • haluk.celikhaluk.celik Posts: 20
    edited September 2022
    yes sir.You can see i selected car
  • nemesis10nemesis10 Posts: 3,991
    Not select the car in the Scene Tab but select the appropriate surface in the Surface Tab? I think you are in the Scene tab in your illustration.
  • AgitatedRiotAgitatedRiot Posts: 4,763
    You need to be here.
    1920 x 1080 - 928K
    Post edited by AgitatedRiot on
    Thnak you so much sir.İt worked.Really thank you so much
    You need to select the surface you want to apply the shader to in the Scene Pane & Surfaces Pane,  If you don't have the Surfaces Pane open then you can open it by going to Window - Panes - Surfaces
  • barbultbarbult Posts: 27,390
    Or you can use the surface selection tool and select the surface in the viewport.
