My DSON importer for Poser stopped working
A while back, I downloaded an update to my Poser 10 app, but when I opened the program afterward I found that it deleted all my DSON importer for Poser content from DAZ Studio. Help?
1571 x 894 - 671K
  • frank0314frank0314 Posts: 15,109
    Did you try re-installing it?
    Click on the folder symbol with a + sign next to it and add the Runtime folder you have your DSON items in.
    Poser 10 or DSON Importer for Poser?
  • Click on the folder symbol with a + sign next to it and add the Runtime folder you have your DSON items in.
    I tried that, but then I got this message:
    1600 x 845 - 631K
    What was the folder you selected?  I don't know if P10 wants the folder containing the Runtime folder, or the Runtime folder itself.
  • What was the folder you selected?  I don't know if P10 wants the folder containing the Runtime folder, or the Runtime folder itself.
    I selected the DSON folder inside Poser 10 because I thought that was where my DSON items were.
    1599 x 860 - 667K
    1598 x 862 - 668K
    1600 x 857 - 666K
    1598 x 853 - 666K
    1596 x 842 - 634K
    1598 x 848 - 655K
    1599 x 834 - 626K
    You only need to go as far as Runtime, don't go any deeper than that.
  • Nah. It just created empty folders. Maybe I should uninstall the program and re-install it, you think?
    And you have both the core zips and the PoserCF zips installed there?
    I believe so. What are the core zips?
    For example, "Genesis Starter Essentials" is the core, "Genesis Starter Essentials PoserCF" is the companion, both need to be installed.
  • For example, "Genesis Starter Essentials" is the core, "Genesis Starter Essentials PoserCF" is the companion, both need to be installed.
    Yes.
    What's the full path to one of the PoserCF files that isn't showing?
    Yes. Did you reinstall the current version of DSON? As Mike said you don't need to go any further than your library folders. There is no need to go inot the DSON folder. Where is you main runtime located?
  • What's the full path to one of the PoserCF files that isn't showing?
    OK. I'm back. Sorry, I got confused. The problem was that I had refered to the wrong runtime folder as you saw in the screen captures I posted earlier. I was trying to load DSON content back into Poser by this runtime folder:
    C:\Program Files (x86)\Smith Micro\Poser 10\Runtime
    When I should have loaded it from this runtime folder:
    C:\Users\Public\Documents\My DAZ 3D Library\Runtime
    I have since resolved the issue.
    I just want to thank you and Fixmypcmike for taking the time to help me with my problem. If I have another issue in the future I hope I can come to you guys for help because I really want to learn this skill.
