Map Images To Objects in Daz4.8 ???
AVU4UAVU4U Posts: 67
How do I map an image to an object in Daz4.8? It used to be so easy in earlier versions of Daz. I would just go into LightWave and make a UV map then import into Daz. Whatever help U can give will be appreciated. Here's an example of what I did for my graphic novel Nocturnes. You can see some of the finished pages of Nocturnes here:   http://avu4u.com/nocturnes.html
2100 x 1352 - 1M
  • Richard HaseltineRichard Haseltine Posts: 111,348
    The same method should work - what problem are you having? No UVs (make sure you didn't miss any polygons when mapping in LW) or something else.
