Can DAZ rig Hydraulic Pneumatic Cylinder Pistons like this ?
Can DAZ rig Hydraulic Pneumatic Cylinder Pistons like this ? https://www.youtube.com/watch?v=st84B470kLk
Thanks
RorrKonn
  • NorthOf45NorthOf45 Posts: 5,896
    Short answer: yes. Put a bone on each piston half (the method varies depending on whether you have an assembly of props, or an existing geometry with or without rigging). With the Joint Editor Tool, set Center Points at the pinned end of each half of the piston (adjust x,y,z positions if needed), then set the Rotation Order so that the bones lie along the length. Select a piston bone, and set the Constraints in the Parameters tab to Point At the other piston bone (select from the list). Repeat for the second piston bone so that they point at each other.
