OT - Does anyone have a model of a bikini machine? - Now You Do
DiomedeDiomede Posts: 15,457
edited September 2022 in Carrara Discussion
(EDit: Freebie attached to post lower in thread.)
Vincent Price made some great movies.
But then he made two Dr. Goldfoot movies and a Dr. Goldfoot TV special.  Here is the first of 3 youtube vids of his TV special.  This TV version has a special appearance by Harvey Lembeck; you might remember Harvey from the truly great movie, Stalag 17.  Or, you might remember him as the leader of the bikers in the Annette Funicello and Frankie Avalon Beach Blanket movies.  I am yearning for the days when the biggest threats to the world were bikini machines.  NVIABMWAS, naked Vicki in a bikini machine with a scheme.
Post edited by Diomede on
«1
    Part 2
    Part 3
  • Steve KSteve K Posts: 3,535
    Maybe you could use the attached, "beat to fit, paint to match".
    700 x 700 - 132K
    Actually, I am modeling my own to share.  The bikini machine is basically just a big cube with greebles on the side facing the camera and a conveyer belt type exit on the side.  You know, a lever and some flashing lights.  It was in the first video, but is actually operated during the first 40 seconds of the second video.
    " ... a big cube with greebles on the side facing the camera and a conveyer belt type exit on the side.  You know, a lever and some flashing lights ... "
    Sounds like something even I might try to "model".  Although I usually spend several hours looking for a purchased model to avoid fifteen minutes modelling it myself.  blush
    FREEBIE ATTACHED AS ZIP FILE
    Free Machine of Villainy.  Make Vincent Price Proud.
    Here you go.  Your very own machine of villainy for all your Republic Serial cliffhangers.  Sorry, you will have to apply your own textures.
    What you get.
    1) A cube with greebles facing the camera.
    2) A lever with rotation constraints to start the machine
    3) A rigged electric cord to unplug in the nick of time!
    4) A dolly with translation constraints so someone can be either fed into the machine or produced by the machine
    5) A monitor on the side of the machine with a UVMap that matches a square.  That way you can use your own image and put any label you want on the machine, or have a countdown, or whatever.
    6) A chute on the other side of the machine to pour in ingredients, or spew out smoke, or...
    7) Curtains with morphs to open where the dolly enters/exits the machine
    zip
    zip
    Machine of Villainy Dio Freebie.zip
    340K
    1559 x 933 - 208K
    aaa02 cube with greebles facing the camera and a monitor to put your label.jpg
    1723 x 836 - 214K
    1684 x 896 - 150K
    1874 x 966 - 250K
  • StezzaStezza Posts: 9,221
    awesome... thanks @diomede ... yes
    800 x 600 - 855K
    Post edited by Stezza on
    That is awesome, Stezza!  Someone actually downloaded and used the villainous machine.
    Some of you are probably just short of campy villainous ideas.  So for you, here is a list of the 1960s version of Batman traps, teasers, and escape.
    See - https://adamwest.tripod.com/traps.htm
    Example.
    "Fine Feathered Finks" & "The Penguin's A Jinx"
    The Trap
    Bruce visits Penguin's umbrella factory to plant a bugging device, in order to learn his next move. But a detection alarm goes off, and Penguin puts Bruce to sleep with a gas umbrella. His thugs tie Bruce up in a net, and put him on a conveyor belt leading to a large furnace (usually used to forge umbrella ribs).
    The Teaser
    "For Batman's sake! Keep your bat fingers crossed until tomorrow!"
    The Escape
    The intense heat wakes Bruce up, but he is unable to get off the conveyor belt. Luckily, he can reach the cigarette lighter in his jacket. He throws it into the furnace, and the resulting explosion blows him onto the ground. He then gets out of his bonds and makes a run for it back to Stately Wayne Manor.
    Or watch this video collection.
    The Supremes sang the theme song.
    used your model again @diomede
    it's very useful yes
    900 x 438 - 606K
  • Bunyip02Bunyip02 Posts: 9,345
    Hope that Hamster gets meal & smoko breaks !!!
    Stezza - that is a much more cool machine of weird science.  The hamster is brilliant.
    Bikini Machine Monitor Screen - Applying an animated shader.
    The bikini machine (machine of villainy) has a monitor next to the lever.  I UVMapped the monitor screen as a perfect square filling up the UVMap.  That way, one can render out an animation and apply it to the shader of the monitor and it will apply.  Best to use the same dimension as the monitor for the animation.
    As a test of animating the monitor screen, I rendered an animation of the genesis 1 figure being morphed from a horrific monster minion to a bikini robot minion.  The genesis 1 is wearing a UVMap bodysuit.  Here is a test of a closeup of the monitor screen followed by the same viewed from a distance.  In the distance view, the monitor is in the lower right side part of the machine.  Should not have used a green background for the distance view.
    Testing, testing
    To use a movie file as an animated shader...
    - open the color channel of the shader tree and choose Texture Map
    - click the open folder to import a file
    - in the list of file types, go to the 'movie files' list
    - in this case, I had rendered to AVI format, so that is what I chose.
    - I also put the movie file in the Glow channel, but that is optional - use to taste.
    1278 x 603 - 135K
    1283 x 862 - 154K
  • HeadwaxHeadwax Posts: 10,562
    sick :) in a good way!
    can you do a hamburger machine - i'm sick of cooking
    Haha, thank you.
    Sure.  Just adjust the setting to burger.  I should have animated this, but I am watching the American Thursday Night Football game.
    800 x 600 - 492K
    800 x 600 - 493K
    800 x 600 - 444K
    800 x 600 - 505K
    800 x 600 - 506K
    800 x 600 - 475K
    800 x 600 - 441K
    edited October 2022
    Pull the lever.
    And the burger emerges.  Burgermeister Meister Burger.
    ha ha now that's a crack up :)
    the awesome machine yes
    800 x 600 - 549K
    edited October 2022
    Oops.
    1324 x 922 - 178K
    edited October 2022
    Dr. Goldfoot's Two Movies Are Included with Amazon Prime!
    Yes, if you have Amazon Prime, you too can stream the villainy of Dr. Goldfoot.
    EDIT:  Amazon Prime rating gives Dr. Goldfoot and the Bikini Machine 4.5 stars!
    1324 x 922 - 178K
    edited October 2022
    How about a Beta Disintegrator?
    Now that you have a bikini machine honoring Vincent Price, you probably need a Beta Disintegrator honoring Zsa Zsa Gabor.  One may be in the works.  Stay tuned.  The classic movie is Queen of Outer Space.  Hits all the vintage scifi buttons of the 50s and 60s.  I think the men's costumes are the same or small alterations of the uniforms in Forbidden Planet.  The danger machines have the same cube-like attention to detail as the Bikini Machine.
    755 x 448 - 69K
    edited October 2022
    This 1958 gem goes all the way into the future - 1985
    And it has a beta disintegrator
    eeeeek!
    'the savage horrors of fearsome mutated beasts!'  surprise
    edited November 2022
    Dr. Goldfoot and the Biini Machine Trivia
    Svengoolie is a camp-horror B-Movie presentation show carried by MeTv.  Here is some trivia about Vincent Price and the gang.  Thought it was interesting that the movie was a big hit in Italy, so they made a sequal with an Italian director and adding a comedy team popular in Italy.
    699 x 877 - 194K
    Wow. What a great thread - even has a Great model to download!!!
    ...and bikinis!!!
    edited December 2022
    ...and bikinis!!!
    Make sure to take some time to enjoy the theme song by The Supremes.  Maybe your band could do a cover sometime.  yes
    Love it!!!
    Reminds me, not long ago I watch the music of 007 live in concert. When they could they had the original artists. When they couldn't, the other artists were brilliant!
    Wow! It's on Amazon Prime!
    Shirley Bassey does the first number! She's still got it, that girl!
    "The Sound of 007 - Live from the Royal Albert Hall" - enjoy! I did!
    Oh right. Rosie reinstated Amazon Prime so I could watch Lord of the Rings - Rings of Power, which was The Best watch I've experienced in a  l o n g  time!
    But alas... we had to let that slip.
    Man, Shirley Bassey!!! (playing in the background as I type this) Oh... and now she's going from Diamonds are Forever into Goldfinger!!! Yikes this is GOOD!!!
