D-Son/P-Son Question
My runtimes are on seperate external drives and upon a time heavily used DS content inside Poser and everything actually worked pretty great. However, now I cannot use any of that content and I'm not quite sure where to even begin to try to fix it and get the magical script that makes the DS content work in Poser functioning again. Does anyone have any suggestions for how to tackle this? Maybe disconnect and reconnect my DS content folder to Poser?
  • Richard HaseltineRichard Haseltine Posts: 111,789
    Certainly for teh DSON Importer to work it needs access to your DS content directory with the DSON Core files (the stuff in the Data folder).
  • GreybroGreybro Posts: 2,708
    Well the library is connected. I mean that is where the cr2's are located. I'll try disconnecting and reconnecting it.
    You also need the \Data folder, ideally in the same library but if it isn't both must be connected.
