Casual T-Shirt for Ayana Doll DS ONLY
ModernWizard
Download from Renderosity: Casual T-Shirt for Ayana Doll Daz Studio Only
Download from ShareCG: Casual T-Shirt for Ayana Doll Daz Studio Only
Daz Studio only Tested only in Daz Studio Pro 4.6 64 bit.
DESCRIPTION Here's a form-fitting T-shirt for Ayana Doll. Made by hand- converting the top from Ghastly's Loose and Casual for Genesis, this shirt autofollows all of Ayana Doll's basic morphs, from Body Fuller to Thighs Inside, and everything in between, including JCMs. I also added a morph to loosen it around her breasts. Note: Even though each piece is rigged as a Triax actor in .duf format, it has no trouble conforming to Ayana Doll if you load her from a Poser .cr2. Just load her from your Poser library, then load the Casual T-Shirt from your Daz content library and fit it to her as you would any other clothing items. **Special thanks to Ghastly for allowing conversion and redistribution of his Loose and Casual outfit!**
LOCATION After installation, find the outfit in My Library > People > Ayana Doll > Clothing > ModernWizard > Casual. To adjust the fit around Ayana Doll's breasts, find the morph LoosenAroundBreasts under Parameters > Adjustments.
SOURCES This freebie uses resources from the following: Hi Res Seamless Hot Pink Jersey Knit by AgathaPaige http://www.sharecg.com/v/27824/browse/6/Texture/Hi-Res-Seamless-Hot-Pink-Jersey-Knit Loose and Casual for Genesis by Ghastly http://www.sharecg.com/v/78876/browse/21/DAZ-Studio/Ghastlys-Loose-And-Casual-Genesis-1
MODEL This freebie is modeled by Ayana Doll, a free standalone Poser figure by Glidman. http://www.sharecg.com/v/81385/browse/11/Poser/AYANA-DOLL-by-Glidman
USAGE NOTES Use for whatever purposes you like, commercial or non-commercial. No attribution needed. Just don't repackage and call your own. Have fun!
ABOUT ME Find a repository of all my 3D freebies at the tacky trove: http://oddpla.net/tacky/ You can see my digital artwork, as well as my other creative pursuits, at my blog: http://oddpla.net/modernwizard/ If you do use any of my freebies in your work, please consider dropping me a line [ModernWizard at the Daz boards and ShareCG, ModernWiz on Renderosity], as I'd love to see what you make. Thank you.
