can't find cyclorama files in latest Daz Studio
SdragonSdragon Posts: 11
i have the mpc,and numerous files for it, in the list it shows up but the current DS doesn't let me load it. grrr what can i do to fix this.
(title edited by mod)
Post edited by Cris Palomino on
  • nemesis10nemesis10 Posts: 4,009
    edited September 2022
    When you say you can't load it, do you mean that
    1. you can't load it from smart content
    2. you can't load it from the library
    3. or you can't load it from products?
    I definitely can load it from the library (Content Library > Daz Studio Formats > My 3D Library > Environments > Landscapes > Multiplane Cyclorama) and Content Library > Products > Multiplabe Cyclorama) but it is probably too old to have smart content metadata.
    Post edited by nemesis10 on
  • AgitatedRiotAgitatedRiot Posts: 4,766
    I searched for products and found them, and they loaded just fine.
    It loaded from smart content. Using Daz Central,
    Ok, I don't have that problem. Every way I tried
    532 x 1069 - 139K
    Post edited by AgitatedRiot on
  • from library.
  • LeanaLeana Posts: 13,501
    So what happens when you try to load it? Do you get an error?
  • yes.
    it says could not find 651 resource
  • tried uninstalling and reinstalling it using daz central, same results
  • felisfelis Posts: 6,502
    What is the error text from the log?
  • There seems to be a very common theme with people who can't load stuff, so common it's hard to ignore. The common theme seems to be DAZ Central. There are people who succeed with DAZ Central, but large proportion of those who do have problems & ask about it in the forums use DAZ Central. It's not often that people who use DIM ask & I'm not sure I've seen there's anyone ask about problems after using manual install. Could be there's a thread here.
    Regards,
    Richard
    Regards,
    Richard
    Daz Central is the default method, it takes some effort and knowledge to find Install Manager, so the association may be correlation rather than cause. (No, I have never worked for teh tobacco industry.)
    It's the whole process that is being presented to new users that's essentially bound to create problems.
    At DAZ site, they are given a link "Download Studio", which doesn't download DAZ Studio, but offers to install DAZ Central instead.
    When the user has installed DAZ Central, downloaded and installed DAZ Studio and the assets that come with it and starts DAZ Studio the first time, the user is presented with a dialog asking for login credentials in a way that one thinks they should be given.
    Having given the login credentials to DS and permission to go online, DAZ Connect within DS starts updating the metadata and 'bugging' the user that the content has not been installed (with DAZ Connect) and makes the user think it has to be installed again, which DAZ Connect does to an other location, taking twice the space on users C-drive (default location)
    As any content installed with DAZ Connect takes priority over the installations made by other methods (DAZ Central/DIM/Manual installation), even when DAZ Connect installed content is corrupt, the user ends up with content that does not work and no way to figure out why...
    There is no warning or notice explaining that logging in to DAZ Studio, is only needed when one chooses to install content with DAZ Connect within DAZ Studio and if one does choose to do that, there is no point in using the other installation methods.
