Single Wing Angel For Genesis by Cute 3D
Hi Cute 3D.
I like this item.
Wondering if it can be made available in a form with and without the shoulder ruffle.
It would be so much more versatile then with many uses. Is that possible.... ?
Thanks.
R
  • wizwiz Posts: 1,100
    Doesn't the ruffle have a separate material zone that you can just set to 100% transparent?
  • larsmidnattlarsmidnatt Posts: 4,511
    even if it did not, you could easily do that yourself.
  • JOdelJOdel Posts: 6,322
    Not necessarily that easily. I don't know whether things have changed since the last time I tried to modify matt zones for one of the vendor's work (it was a while ago), but when I did I discovered that it was all triangular polys and didn't really follow the rational edges of things.
    always worth a try. and better than waiting for someone else to do something for you for a slew of reasons. Nothing worth doing is super easy ;) But I expect it would be doable :) even if you end up using transparancy maps instead of making new surfaces, it is possible.
    knowing how to do that would empower the user for other projects.
