how to use the spot render option
VicS
can I get the directions on how to, cant find any video on it or figure it out how to, I cant even find the command for spot render this time I looked, (thought I had always found it in the past),
thank you for the help
Click on the Spot Render Camera Icon
Use the mouse to select the region in the viewport, and it will render
If you want to render it using the active camera then select the Spot Renderer in the Active Tools Options - then switch to New Window as Viewport is the Default Option.
Available under: Window > Pains (Tabs) > Tool Settings
Thnaks nicstt!
