Why the result of texture is different between DAZ and Blender?
JamesJames Posts: 1,191
edited September 2022 in Daz Studio Discussion
I made shaders on blender, baked them, the diffuse, normal, glossy and roughness map.
Then I put those maps to DAZ on a cloth, but the result is very different.
How to make it like Blender, it really looks like a silk, while on DAZ it looks like a sheet metal?
https://prnt.sc/kg6SkRfZSBli
Post edited by James on
  • PadonePadone Posts: 4,353
    It may be just because of the different light, in blender the cloth seems to reflect a blue sky. When "designing" a material you should always test it in different light conditions to see if it behaves realistically. Otherwise a material could be great with a specific light and not so great with another light set, as it is probably the case here.
    Post edited by Padone on
  • scorpioscorpio Posts: 8,533
    A blender shader won't work in DS they use different rendering engines.
  • nicsttnicstt Posts: 11,715
    Cloth is hard work in Studio.
    Took me ages to get the effects right, and even then, they need tweaking for each cloth type (and light sometimes too).
  • JamesJames Posts: 1,191
    Ok, thanks for the information.
    At least I can set my expectation.
