Content moved categories not working
edited July 2015 in Daz Studio Discussion
My content drive letter got changed so i to add base directory myself but now all my categories that i created arent working. Anyway to get it working properly.
Post edited by witcherask_a3dd58a1c6 on
  • Richard HaseltineRichard Haseltine Posts: 111,756
    If you find an entry in the products list and right-click on it you should see Database>Edit Base paths in the menu. Select that and change the path to the new location, telling it to Change All Files using this base path.
  • I dont understand where do i rightclick?
  • srieschsriesch Posts: 4,243
    In the Content Library, right-click on a content thumbnail.
  • content doesnt showup in categories only its name shows up so how can i rightclick it
    Where are you looking? You should be seeing the files listed - if you see only the folders it may be that you have part of the pane collapsed, please post a screenshot.
  • Here you go no files are listed
    1836 x 907 - 128K
  • Any Help??
    Sorry, I missed your reply. OK, the file area is visible. I can't see any display issues there, so it's not the simplest fix. Do the items show up under Products?
  • It showed up only after i reimported met data. But categories still doesnt work.
    Sorry, I don't know what more to suggest you try.
  • So i guess no other choice than to re categorize everything again
  • fixmypcmikefixmypcmike Posts: 19,732
    Have you ever Exported User Data?  It looks like you did a Scan known directories for content, which would colear out all the orphaned entries.
  • I dont think i have done scan known directories for content.
    I have not exported user data recently.
