Scene Optimizer issues (kind of solved)
DefaultNameDefaultName Posts: 431
I used Scene Optimizer to try and reduce clutter on my scene. I started the script where it checked boxes of things that had high memory, and chose the option to remove displacement maps. After that, Daz3d started crashing. I tried isolating the problem and it's not working.
Now all my scenes crash Daz3d. Even old ones. I can't even use my base figures properly. When I try Iray preview on a base G8, Daz3d completely crashes.
*Edit* - I think because I used this on G8s with geoshells it just messed up all my G8 scenes, as I later discovered my G3 figures never had a problem. After reinstalling G8 so far is has not crashed again, but I still don't know what the exact cause was to begin with.
Post edited by DefaultName on
  • Richard HaseltineRichard Haseltine Posts: 111,306
    edited September 2022
    Scene Optimiser makes copies of the files it modifies, it doesn't touch the originals. That sounds more like an issue arising from chnaging the Viewport Drawstyle, a driver or system update, or even a possible hardware or system issue. Unfortuantely it is very hard to diagnose.
    The files Scene Optimise Creates go to the temp filder, which by default is on the boot drive - it may be worth checking that isn't running out of space. You can move the temp folder in Edit>Preferences.
    I put SO's temp folder in My Library.
    I ran SO on a scene with G8s. My G8 figures crash Daz3d now. My G3 figures however, do not. Currently I'm trying to test if I need to reinstall all my products from that scene, or if I can just uninstall SO.
    I can't prove it's SO, but this all started immediately after I used it.
    Okay everything is fine again after I uninstalled SO and reinstalled G8 essentials. I suspect this happened because my G8s had geoshells and certain products, like Mesh Grabber, just don't work with geoshells. And somehow that got cached or something.
  • Well, I wouldn't put the temp folder in the actual content library - there is no reason to, and it risks file conflicts. You can certainly move it to a new location, though. Still, I'm pretty sure that it won't actually overwrite the main files as the names need to be distinct for DS to distinguish them.
