apps run minimised and wont open?
Hi
I have a new install of windows 8.1 and a clean new install of daz studio, when i try to open them it is minimised and refuses to open any idea's
there are also a lot of broken links out there and no way to search the forum so sorry if its duplicated
    Do other programs do that too?
    Have you tried running DAZ Studio as Administrator, it usually requires that?
  • KeironKeiron Posts: 419
    edited July 2015
    Hi Jimmyc_2009. Yes other programs do this too
    However here is the solution
    Solution
    Press the Windows button and P on your keyboard connected to the PC
    This gives you the option to select from 4  settings
    Choose PC screen only
    Im using dual monitors for some reason setting it to Extend, causes an Issue
    The Geforce 970 card has 3 display ports + HDMI + DVI
    I was using 1 display port to HDMI + DVI via a converter to HDMI
    I have now bought two Display to HDMI cables and all is well
    Post edited by Keiron on
