How do I make multiple copies
Having trouble figuring out how to make many copies of things so i don't have to keep inserting them and then resizing again and again. What's the trick?
In which application? If you are referring to DAZ Studio, you have two options.
One is to duplicate (copy) the object. From the menu, Edit > Duplicate > "Duplicate Node Heirarchies".
Your other option is to create an instance of the object. From the menu, Edit > Create > "New Node instance" (or "New Node instances" for more than 1). Instances are exact copies that are tied to and reflect most changes made to the original object (materials, etc.) although you can still make them different sizes. You would do this to make 100% identical objects to use less memory.
