Installing Photoshop Bridge
I can't Install Photoshop Bridge for Daz 4.8, my Photoshop ver is old "CS2 32bit"
I get this error using install manager:
'Install Manager cannot find a required path. The package for "Photoshop 3D Bridge for DAZ Studio 4.8+ (Win 64-bit)" requires that the installed path for "Photoshop CC, CS6, CS5, CS4 (64-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again."
Is there a bridge for my ver. of PS? If so please post a link here in reply...
TIA!
Simple answer is no.
Okay thank-you for reply!
I don't know it you have found a solution for your problem, but this help me:
The Genesis Evolution morphs are for Genesis, not Genesis 2. There are separate morph packs for Genesis 2 Male and Genesis 2 Female.
Do you have Photoshop? If so you need to click the gear icon at top-right of the Install Manager window to open the preferences, then go to the Application tab, click the + button and set the options in the dialogue to Photoshop, your version and bit-depth, and then click the ... to select the application folder.
if I understnd you correctly you are trying to export from Daz to Photoshop but keep the Daz render as iz, then flip back n forth until the effect is what you want well sorry but as richard-r said the answer is no.
I've gone from Photshop7 through the stages to the present Photoshop CC 64 bit, and it will not work until you get to a much later version of Photoshop when a plug-in is needed then it may work in 32bit, but 64 bit is much better
Do you in fact have one of those versions of Photoshop installed? If so you need to add it to the list of Installed applications - click the gear icon at top-right of Install manager, go to the Applications tab, click the + to add a new application, set the name and version, and click ... to set the path.
I have Photoshop 2017 and no matter what I do DIM will not install the Bridge> Yes I am using the right directory as I used the same directory when I installed the Bridge Manually. Now it works. :)
