How To Rotate Something 360 degrees?
https://youtu.be/tXyZFouhhZ0
I want it to keep it rotating 360 dgreed and make a loop but when I go past positive or negative 90 degrees it reverses direction. How can I make it do what I want?
  • hansolocambohansolocambo Posts: 649
    edited September 2022
    Common thing in animation with any 3D app. Instead of making a 360 degree, create 2 keyframes with each a rotation of 180 (or 4 keyframes with a rotation of 90).
    Example with a 360 clockwork Y Rotation on 20 frames :
    0 : Y Rotation : 0
    (5 : Y Rotation : -90)
    10 : Y Rotation : -180
    (15 : Y Rotation : -270)
    20 : Y Rotation : -360
    Use keymate to set interpolation type on all keys to linear. Or a smooth TCB curve (Tension, Continuity, Bias) is generated and your animation won't have a constant speed.
    Post edited by hansolocambo on
  • DarthDDarthD Posts: 259
    https://youtu.be/t0uzHT9D_KI
    Thank you, that worked!
  • FishtalesFishtales Posts: 6,232
    I used this.
    I may check that out at some point
