Interactive Lessons
I have downloaded:  Interactive Lessons for Daz Studio 4.8+  but am confused on how to use it?????  Is there a Help File about these interactive lessons???
Thanks    Ron B
    If you go to Help > Home > Interactive Lessons, you should get a small bar at the bottom right of the interface which is labelled 'Select A Lesson'
     Did you install using DIM (DAZ Install Manager)?
  • Yes, I used DIM.......  It's a great way to get everything in the correct place.
  • frank0314frank0314 Posts: 15,117
    edited July 2015
    Plus you get all the updates to products which there is a lot of. Manually installing you never know when there is an update.
    Post edited by frank0314 on
  • If you go to Help > Home > Interactive Lessons, you should get a small bar at the bottom right of the interface which is labelled 'Select A Lesson'
    I think that Daz might consiter making the damn bar a bit more obvious.... Until you referred to it I had never noticed it.   Thanks for pointing me in the right direction.
    The lessons are there.
