Need help with animation.
Hello everyone. I have a problem.
Could anyone explain how to lock feet on the ground? I tried to search internet with diff keywords such as (ik/fk for daz3d, lock, pin e.t.c) but no result.
Maybe i need to create the ground to pin feet to it? But where can i find this tools?
I pinned feet, but it didnt help.
I want to make animation using puppeteer. Just stand sit positions. 0 frame (key) - Stand / 15 frame (key) - sit. But between, characters feet fall through the ground.
Many thanks for prompt help.
DAZ Studio does not have a Ground (unlike Poser) so you could create one by using a plane primitive, Create > New Primitive > Plane, and then perhaps the feet would 'pin' to that?
You can use Ctrl+D to drop a figure to the floor (even if there is no floor there)
Yep, (Ctrl+D each frame very annoying thing) but feet still slides. As I understand, there is no solution in Daz3D yet. Here I saw the request video, exactly what I need:
And if you use Ctrl+D, then it will change the attitude for characters next frames, not good at all.
