Daz3D Hardware
Someone who has Ryzen 5 3600 with GTX 1050 ti or 1650 , Please render any same character with these following options (1) CPU only (2) GPU only (3) CPU + GPU And share the rendering time with me ! It would be helpful for me ! Thanks!
  • nicsttnicstt Posts: 11,715
    Use the GPU only, and there is a thread somewhere with render times, check it out for times of renders
  • alan bard newcomeralan bard newcomer Posts: 2,433
    edited September 2022
    when I did do checks...  gpu fast gpu+cpu 5% faster ... cpu slow. (and I have dual xeon 2630v3... older but that's 16 threads all going and still can't catch the gpu and the diff between gpu and gpu+cpu is so little why listen to the processors scream
    Basically for daz with iray... the gpu is the hardware. faster cpu might get it to the card a little faster that's all
    with a 1050ti any 3xxx series would be an upgrade...  I have a 1050ti and it has 1700 cudas half of my 980ti and maybe a third of my titanx
    so even the bottom 3xxx cards will give you more cudas, more speed and more vram.
    --- for me I'm stuck... outside of speed increase in the cards... I have to hit at least a 3070 to get more cudas and 3080/90 to get more vram.
    Post edited by alan bard newcomer on
  • I've Ryzen 3200g and 8gb ram , should I switch to 1050 ti ? ( I don't wanna buy higher end GPU like rtx 2xxx or 3xxx whatever) and ( Also I don't render any complex scene ... my work is to only render single HD character ) like this : (example)
    1000 x 1300 - 122K
  • Richard HaseltineRichard Haseltine Posts: 112,049
    A 4GB non-RTX card is going to have very little room for rendering as it will lose a chunk to the code emulating the RTX features. Not that 8GB of system RAM would support a larger card.
    Going with bare minimum, you need 16GB's of RAM and a supported Nvidia GPU with 6GB's of VRAM, preferably 32GB's of RAM and 8GB's of VRAM on the Nvidia card.
    Scene "complexity" is not that straight forward, a piece of clothing or hair can have a large vertex count and large textures with lots of maps, which can already make the scene too "complex"
    On the other hand one may have a city scene with people that doesn't tax the system as much.
    It's all about knowing what to put into the scene, especially when working with low end systems.
  • Thanks to all
