How to kill projected corrective morphs for G3
j cadej cade Posts: 2,310
What the title says. I am making a dress for genesis3 and the corrective morphs projected from the shins are ruining everything. Since they are automatically created, if I delete them they are just respawned next time I load the dress.
I tried to create a replace the morph with version that didn't move anything but daz wont let me import a morph that is exactly the same as the base.
How do I KILL it? ARGH
    12 gauge Remington pump?
    That probably explains what's happening with the boots I'm working on, too.  They have a folded cuff at the top that is somehow getting messed up and I bet it's the same reason and not the last shreds of my sanity finally moving to Tahiti.
  • Cayman StudiosCayman Studios Posts: 1,145
    You create an Empty morph with the same name as the existing morph.
    Set the parameters tab to Edit Mode, locate and delete the existing morph, then right-click and select "Create New Property".  Give the new morph the same name as the one you have just deleted, hide it, lock it, and check "Create As Empty Morph".  Now save the dress.
    Next time you load it the empty morph will load and will block the G3 morph.
