Genitals to large
orandaoranda Posts: 22
Apologies if this topic is distasteful to many but...
Why are the genesis default male genitals so large.
When trying to produce a pose based on a real human photograph. invariably the genesis genitalia are too large. This include girth of penis, length of penis, the size of the scrotum, and the distance they including testes drop from the body.
Simply applying a scale size downwards doesn't do the trick, but only after lengthy fiddling can something near realistic be achieved.
The default size is more akin to a porn star than the ordinary man in the 'street'. I'm looking for the appearance of genitalia that have been exposed to a cold dip in a pool, tight and perfectly proportioned.
  • BlumBlumShubBlumBlumShub Posts: 1,108
    Well... He works out!
  • mikael-aronssonmikael-aronsson Posts: 605
    Customer demands maybe :-)
    But what's the problem, it does not take many seconds to change the size ?
  • orandaoranda Posts: 22
    Maybe your better at it than I am but to get the genitalia to appear natural it takes me much more than a few seconds.
    For instance the width of the scrotum with the testicles can be too wide and oval shaped whereas I may need it to be more spherical, bringing the two testes closer together, and thus the scrotum rounder is not easy.
    Ok, but still, you want it "perfectly proportioned", I would guess the meaning of this is different for different people, so even if the default was smaller you would still not be happy and have to change it anyway.
    Even if it takes some time to play around with the morphs, once you found the perfect proportions, save it and keep it for next time.
  • rogerjhardy100rogerjhardy100 Posts: 297
    The G2M genitalia size can be changed without going to the global 'scale' dial. The genitals consist of four parts that can be changed, Gen 1, 2, 3 and testes. Just expand the selection in the contents tab. These can be individually changed (scale, x, y, z, bend, side-to-side, twist, etc) to get exactly what you want. Overall, I think that DAZ have got them about right but it's impossible to be objective as everyone is different but we all have our own ideas about what is acceptable or normal. You cannot go by classic statuary as they understated the genitalia to avoid distracting attention from the main body.
    Thanks for the pointers I'll give it another go, and I go with what you say about 'normal' and the classical nude.
