Cloth disappears when simulated
James_1597261James_1597261 Posts: 1,191
edited September 2022 in Daz Studio Discussion
I don't understand what's going on.
I tried the solution from this thread. Not working. Well it worked before, but now, it's not.
https://www.daz3d.com/forums/discussion/322096/clothes-disappear-in-dforce-simulation
Select the object with dforce applied
Go to Edit-Object-geometry-select dforce starting collision verticies
Select your geometry editor tool and right click the select selection type and vertex
this will then display the collided verticies.
Go back to your 3D editor and find thoes verticies
pull them around and you will find hidden faces or edges
delete the extra geometry or work it in just not collided and re save or export your item
import the new item into DAZ and it should work.
This is the dress which I have retopologized manually.
https://prnt.sc/FhFH_SNK0lCn
Post edited by James_1597261 on
