Morph help please?
DisparateDreamerDisparateDreamer Posts: 2,520
I think i'm forgetting or missing a step in making my own morphs. I have the morphs- i have tried both with deformers and with morph loader. I can make it show up, once. The problem is, when i save and apply it, it doesn't work. I'm missing something. I've done it before but i can't remember now. :/
I save the morphs as a char preset (this is for genesis, genesis 2, or genesis 3) or shape preset. The morph shows when I'm saving it. But it won't apply later. When I use deformer based shapes i spawn morph from the deformers and then try to save it. It's not working tho. :(
Not sure what i'm doing wrong... did something change between versions of Daz? I know it was working before.
Thanks for help.... don't want to loose all the morphs I'm making :(
  • barbultbarbult Posts: 27,670
    Did you save the morph as a support asset-morph asset?
  • timnaastimnaas Posts: 123
    Exactly what "barbult" said......
    Once you have the morph you want to save, "save as/support-asset/morph asset"
    Just remember that you only have the morph you want checked when you open up genesis/genesis2/genesis3.
    If you have any trouble, let me know and I can show you more screenshots.
    1920 x 1080 - 367K
  • DisparateDreamerDisparateDreamer Posts: 2,520
    Aha! I knew it'd be something simple like that! Thanks so much :)
    The character preset is for saving it AFTER the morph is saved. That will let you dial it in (if you split it into head and body, dial both in) and even save skin/material settings. In other words a 'complete' character...
    The shape preset should be similar, without the skin/materials.
