Luminance value
N-RArtsN-RArts Posts: 1,603
Hello!
I'm starting to render external scenes with Iray.
I'm using a skydome, which with the iray shader added gives it an emissive value... as you probably know :P .
Anyway, I'm using Watts (at least, I assume it's watts) as the luminance value (because it's the only one I know anything about ^^').
At the moment, I've got the luminance units turned up to 70000000000... Which is okay as it's lighting the scene pretty well.
However, I was wondering if anyone knew of the perfect/optimal luminance value to recreate daylight (lighting a scene perfectly or, as close to perfect as possible).
Thank you
