Saving Gen7 clothing set up for Gen8 - Answered, many thanks.
richardandtracyrichardandtracy Posts: 8,171
I wonder if anyone could help me.
I have a certain amount of Genesis 3 clothing, and I only use Genesis 8 (or occasionally 8.1). Each time I use the Genesis 3 clothing on a Genesis 8 character I have to remember to deselect the character, load the clothing, change the compatibility base of each piece then fit it to Genesis 8.
This is slow & inefficient, doing the same operations multiple times. I'd like to do it just once.
Would saving a wearable preset of the clothing keep the changed compatibility base so it would load properly on Genesis 8 without needing to remember to do all the faff each time? And if not a wearable preset, is there any way of doing it?
Look forward to hearing if it does - I've not tried it myself yet because I don't want to risk damaging the clothing's fit to Genesis 3 and I can't tell from the abundance of technical documentation published by DAZ whether it'll work.
Regards,
Richard.
Post edited by richardandtracy on
    I think the combatibility base is saved in metadata (Runtime\Support), using Notepad++ it should be possible to search and replace that information for a bunch of files at the same time - Afterwards, refresh metadata in the database.
    Sorry, should have read the complete text before replying...
    If you save an item as wearable preset after changing the compatibility base, it will load on a G8/G8.1 figure just like one made originally for G8/G8.1.
  • Absolutely perfect, thanks.
    Just the info I needed. I will do that & keep the Genesis 3 clothing files untouched so I can start to use Gen7 at some point if I want to & have it work perfectly still.
    Regards,
    Richard
  • Just be sure to save to different folders than the ones the original data files are parked in.
  • Do you have to do that with a wearable? I just thought it tweaked the way a data .dsf was interpreted. Regards, Richard.
    You don't have to worry about it with a wearable preset
    I always save to the clothing folder of the character I've converted the clothing to as it makes it easy to find.  That said I use my own categories not smart content.
