water remaining transparent no matter what. Iray
HorusRaHorusRa Posts: 1,666
edited March 2019 in New Users
Post edited by HorusRa on
  • Richard HaseltineRichard Haseltine Posts: 111,875
    Which water preset are you using? If it's only a plane, not a solid volume, you need to use the thin settings.
  • SzarkSzark Posts: 10,634
    If you used the Thin water shader try dropping the Refraction Strength.
  • HorusRaHorusRa Posts: 1,666
    edited March 2019
    edited March 2019
    Water is not the same as Water - thin. The former requires a solid, not a simple plane.
    Refraction Weight (Weight means strength). Also if it is a Plane, single thick mesh then you should be using Water Thin. Refraction Weight of 1.00 will make the water clear, dropping the weight with make it less transparent. Also there is no need to apply Uber Shader before applying a different Iray mat preset.
    edited March 2019
    edited March 2019
    edited March 2019
    Have you tried putting a plane underneath the water as I suspect you might be getting the HDRI showing from below. Just a thought.
    Or you could use a cube http://www.daz3d.com/forums/discussion/57355/P300/#839453 with these settings http://www.daz3d.com/forums/discussion/53695/P660/#835496
    and here are some tuts on using the Geometry Editor Tool to do want I did http://www.daz3d.com/forums/discussion/18401/ and http://www.daz3d.com/forums/discussion/42088/
    edited March 2019
    Can't you duplicate the plane and move it back toward the horizon? What it the background a plane with an image on or a Background.
    I am hitting the sack now so I won't be back until tomorrow.
    edited March 2019
    edited March 2019
    LOL Yeah just shows how tired I was...background is a HDRI and should be all counts show up in reflections.
    Thanks it was a sticky one but I got a few hours of sleep in.
