Missing Files Error Referencing Old dsf File
Where all does Daz Studio store references to object dsf files?
Here's the scenario....
I am creating a custom outfit consisting of a number of different clothing items. First round through, I set everything up and saved out the support asset files, and everything was fine. But there were some issues with geometry and UVs of some of the items, so I went back to my modeler and tweaked them. Then I loaded the new objects back into Daz and set everything up again (transfer rigging, morphs, etc.). When these new items were ready, I deleted the item folders from the /data directory and saved new support assets, overwriting the existing duf files.
Now, when I load any of these items from the Content Library I get the Missing Files error dialog, and it shows a path to the old version of the item's dsf file under the data directory. I cannot find any reference to these old files. Why is Daz Studio still looking for them? Are these references cached somewhere? I have restarted Daz Studio, and I have even restarted my computer. Still get the missing files errors.
I have put so much work into this outfit, and I'm so close to being finished! Can anyone help me solve this issue?
Tim
  • felisfelis Posts: 6,648
    Try to open the duf and search in that.
  • Thanks. First place I looked. All references are to the new dsf only.
    I would assume that the log must have information on what is was doing, when it looks for these items.
  • BejaymacBejaymac Posts: 2,014
    Missing DSF asset warnings usually come either from a DUF file with a bad pathway, or a morph DSF with a bad Parent pathway.
    I did find references to a cache file....
    2022-08-31 22:17:25.498 [INFO] :: Cache update required, 98 unused files: /data/xxx/xxx/xxx.cache.dsf
    This is shortly before the error shows up. This must be relevant, but I can't qactually find such a file. Must be hidden or something.
    I did find a workaround that let me move forward. I just had to resave each item using a differnt product name in the support asset dialog. That creates a different subfolder under data, presumably along with a new cache file.
    Tim
  • Cache is here {default install location}: C:\Users\......\AppData\Roaming\DAZ 3D\dson\cache\data   And yes, the AppData folder is a hidden folder.
    After D/S is closed it is safe to empty everything in the data folder.
  • Good to know. Thanks for the info.
