Eyelashes not lining up with eyes on Face Transfer characters.
Pretty much what it says in the title.  Is there a fix for it?
I'm running the Studio 4.20.0.17 (64 bit version) on a Windows 11 laptop.
Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz w/ 32 GB RAM
NVIDIA GForce RTX 2060 running the 516.94 Studio drivers
1000 x 1300 - 1M
  • Would it help to delete those eyelashes, select the figure and add a fresh set of eyelashes?
    Just tried it.  Unfortunately the results are the same.
  • felisfelis Posts: 6,558
    Does it change anything, if you with the joint editor tool selected, right-click in viewpor Edit > Adjust rigging to shape?
    Yeah, the viewport goes black and everything breaks.
  • Well with Headshop as I recall, one has to check the morph that one is making to be sure that the "auto-follow" is selected. Remove the eyelashes, check the face morph that auto-follow is selected, then try applying a fresh set of eyelashes.
  • Thanks Catherine, that worked for me. I'm amazed that such a simple issue is not done automatically by HeadShop.
  • Well it would be IF it checked that box when making its morphs.
