can g3f work in external ds runtime?
MistaraMistara Posts: 38,675
was wondering if can set it up as an external MyLibrary?
what happens to ds if external is on a flashdrive and the flashdrive isn't plugged in?
    If it's completely external and you are using CMS, there will be some icons with the AWOL look to them...but if you aren't using CMS or don't really care, not really amuch of anything...she just won't be there.
    okay. thanks :)
    got a lovely new 128gb flashdrive take some of the weight off my groaning hd.
    every time i start saving for a new compy, life throws a surprise bill my way. like hurty tooth. oww
    Any content can be used in an external location as long as D|S and (if you use them) the CMS and DIM have been set to look at where you've put the files.
  • TheKDTheKD Posts: 2,711
    Yes, I don't have en "internal runtime" to speak of. I do however have 5 runtimes on an external hard drive. You will just have to go into the content directory manager and add it there, and everything will work as it should.
  • NadinoNadino Posts: 258
    Yup, as long as that external runtime is mapped in DS it'll work just fine. Used to have 19 and never had issues :)
  • almahiedraalmahiedra Posts: 1,370
    Yes, currently I have DS program in C hd, but all content in external disk U.
    I recommend that you change the letter of the disc to the last in the alphabet to avoid unwanted change in rute when other device are connected/disconnected.
