Dont see the sky in Daz 4.8
leefootleefoot Posts: 0
OK.
I am not a new user of daz3d but I took a break for while (when it was 4.6).
And now, when I tried to render the sky with the character it's render ONLY the character with a black background,
What should I do?
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Are you using 3delght or Iray? If you are using 3Delight, and are saving to a format such as jpg that doesn't support an alpha channel, then you may want to use the new Environment pane to set the background colour - by default renders are against transparency, which is saved to Toff and PNG but not to other formats; the viewport background colour is no longer used for rendering, only for display.
