Filtering Product Library for Genesis (1) Items?
Can anyone suggest filtering terms to find Genesis (1) items in my account'sproduct library? I don't think Genesis 1 will work and of course Genesis gets me items from G1-8.
    edited August 2022
    If you have installed the Daz-Deals plugin to your browser, you can filter the shop to "Only Show Owned" and use the regular filtering options to limit the products to "Genesis"
    This of course works only for products that are still available in the shop.
    Post edited by PerttiA on
  • TaozTaoz Posts: 10,345
    This one has a filter with which you can find any genesis version using the Exclude option, provided "genesis" is part of the product name.  It also has DS integration so you can find any product in Content Library with a few clicks (requires that products are installed using DIM).  Free for up to 1000 products.  See video:
    https://www.screencast.com/t/S60ZmJrdxc
    https://www.taosoft.dk/software/pm-daz/
  • IceScribeIceScribe Posts: 694
    As you find your "Genesis" (1) products, sometimes there were figure products labeled as V5, Victoria 5 or M5 Michael 5.  I have set my own categories in the Smart Panel. I use G1, G2 G3 etc for each figure after I install them. Less typing and really fast. Another trick I use is to load the Genesis (1) figure, select the figure and then scroll down to Wardrobe, and click the little box to show only items related to the selected figure.This will get you started on finding the matching products. You can then set G1 in the "Explore Product", by selecting one or more products, call up the category pane, and create your own category. Also check out the Lost and Found, there are often many items clicked "Lost" . Unclick them, and then choose your own category. The categories only relate to the Smart Panel search box. Adding or changing the categories doesn't change any product. Hope this helps.
  • Thanks for the tips!
