Error "Files does not exist" when using Aiko 3.0 Ultra Catsuit
Blakmoon
Hello All.
I have a problem using the Smart content "Aiko 3.0 Ultra Catsuit".
In the Smart Content panel, I see it and all its files.
When I double click on one, per example "Aiko 3 Catsuit", I have the message "Could not open file : /Runtime/Libraries/Character/Aiko 3 Clothing/Aiko 3 Catsuit.cr2 File does not exist."
Its the same with every file.
But if I search it, it does exist, and I even think that when I open this file, it IS the file mentionned in the message, I found it with the function Browse to file location...
The only way I managed to use it is to place those file in the content "Poser Formats".
Do I miss something using this asset (I'm using DAZ 4.20) ?
That often happens if the product was double-installed, once through Daz Central or Install Manager and once through Daz Studio itself, then the Daz Studio manually deleted or moved - Daz Studio will still try to load the files it installed, and ignore those from other methods. If you right-click on the product thumbnail in Smart content is there an Uninstall option? If so, use that and see if the product will then load correctly.
Thank you for your response. After uninstalling into DAZ, the catsuit was no more available. Then, I uninstalled and installed it again in DAZ Central.
And now everything works fine
Thanks
